Light mix & light texture problem
  • Light mix & light texture problem
    Vray 5.20.06
    Rhino 7 I think it is was SR23.
    File size around 20MB
    8700k 32gb, RTX2070 8gb
    Hello,
    This happened a couple weeks ago. Created a light with a bitmap in texture slot. Production CUDA (CPU & GPU) render. Used light mix on this light and other lights. Then "to scene" to save light settings.
    2 attached images show light before & after corrupted light mix.
    File then became excessively slow to open, and render, a several minute pause.
    To fix temporarily, I deleted the affected lights, importing the file into a clean Rhino file, remade the lights, then didn't use light mix when I have textures in any light slot. File then rendered fine.
    The same situation occurs when I used procedural noise "B" in the texture slot (simulating a disco ball light effect on walls & floor).
    Shown light is rectangle, also corrupts with spotlight.
    Thanks,
    Glenn
    Dear glennco​, hello.
    Excuse us for the delayed response!
    The described from you is reproducible on CPU too and also with V-Ray 6.
    I have logged it in our bug tracking system with VRW-3910 number for further investigation.
    Please confirm that the shown scenario is happening after clicking over To Scene more than once - every next click is creating the new nested Mix (Operator).
    According to my tests this is happening.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      tsvetomira.girginova,
      Thank you for the reply.
      Yes, every time you click "to scene" the nested mix is created and grows.
      I recently switched to Vray6, so thanks for the heads up.
      As a workaround (with a texture light), I can use light mix, without clicking to scene, instead manually adjust the lights.
      Glenn
        Thank you for the confirmation, Glenn.
        Our dev team will look at this.
        This nested Mix (Operator) could be seen also in Textures, since it's created also for the Environment texture.
        Еven though it affects the UI, the values are properly translated from Light Mix to V-Ray Asset Editor.
        But we understand that it is a disadvantage and requires more clicking - you have to be precise where are you adding changes, will they apply to the texture etc.
        Thank you once more for reporting!
        We will inform you by any progress.
          Hello glennco,
          I would like to let you know that the issue is fixed and the fix will be included in the next update.
          Kind regards,
          Iva
          Iva Mancheva
          V-Ray for SketchUp | V-Ray for Rhino | QA
          www.chaos.com
            iva_mancheva,
            Iva,
            Thank you for the notice & I look forward to the next update.
            Glenn​
