Slider range of dir lights
  • Slider range of dir lights
    ... could be set so that 1 is at the middle position of the slider, because this light type is without decay and the typical needed range is from 0.1 ... 10. For example at the moment it's difficult to set a value like 0.7 per slider.
    Best-
    Micha
    Hello, Micha ,
    Thank you for your feedback. I logged an improvement suggestion for increasing the default slider range so that 1 is the mid value, which will allow setting values greater than 1 with the slider.
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
