V-Ray Setup no saved at Rhino 8
  • V-Ray Setup no saved at Rhino 8
    the setting for s-RGB slider, advanced materials and custom material library are not saved and available after reopen a Rhino file at a new Rhino task.
    -Micha
    Hello, Micha,
    Was not able to reproduce the behavior you described.
    Can you please specify the exact version of Rhino WIP and V-Ray you use?
    Do you switch between V-Ray and Rhino default render engine at some point?
    Peter Chaushev
    Let's keep in touch
      I just tested it again and it works here too. Maybe my Rhino has a temporary problem or the last update fixed the problem.
      Thank you,
      Micha
