Mix map is not working properly
This topic has been answered.
  • Mix map is not working properly
    https://www.screencast.com/t/sMphCtU7LOZi
    The result of the mix map is not what I expected. It is way darker.
    V-Ray 6.1
  • Answer selected by natalia.gruzdova at 22-08-2023, 12:09 AM.
    Thank you javierrentas for sharing your material. While I was recreating it I noticed that you have a Color Multiplier set to 0.07.
    In material setting Switch to Advanced Settings and change Color Multiplier to default 1 for example.
      Hello javierrentas,
      Thank you for the video.
      I have tried to recreate similar material in the 6.10.00 V-Ray version and it seems to be working as expected.
      Can you please share your scene with material and texture for us to take a look?
      Thank you in advance.
      Natalia Gruzdova | chaos.com
        I have the latest version of V-Ray 6.10.01 and I had the same mix map issue. Definitely, there is something odd
        I'm attaching the material
            Thank you!
            No idea how that setting was changed. OI only touch those multipliers when the Mode is set to Blend.
            Best
