Dome light toolbar button no longer works
  • Dome light toolbar button no longer works
    Since the last Vray for Rhino update (version 6.10.00), toolbar button for dome light (same goes for "dome light as sphere") no longer works. I use Rhino 6.
    The workaround is to:
    - create the dome light through the Vray menu
    - edit the toolbar button command (change from default "_vrayLightDome", which no longer works to: "_vrayLight 0 6 0"​
    Hi matej_p,
    Thank you for reporting the issue. It is now logged in our bug-tracking system.
    Please, note that Rhino 6 support will be discontinued soon. You can follow this thread for further information https://forums.chaos.com/forum/v-ray...ums/v-ray-for- rhino-announcements/1183758-rhino-6-support-discontinuation.
    Kind regards,
    Natali​
    Natali Velcheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaosgroup.com
      In addition to the dome light button not working, the following buttons also no longer work:
      Sphere Light Tool
      IES Light Tool
