Screen Image in the environment is not working on GPU
  • Screen Image in the environment is not working on GPU
    Hi guy
    I want a backplate in RTX mode, but it is not working. Is this mapping type supported on GPU rendering?
    It is working fine if I use CPU
    The latest version of V-Ray 6.10.01
    Hi, javierrentas
    This is a known issue that has already been logged in our bug-tracking system. We'll let you know when there is an update on the development.
    As a workaround, set the Environment Background multiplier to 1 and use the V-Ray Color Correction texture to increase the intensity of the HDRI. Please, let me know if this works for your project.
    Kind regards,
    Natali Velcheva​
    Natali Velcheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaosgroup.com
      Hi, javierrentas
      I would like to notify you that the described issue is fixed in the 6.10.02 build.
      Thank you again for reporting it!
      Kind regards,
      Natali Velcheva​
      Natali Velcheva
      www.chaosgroup.com
        Thank you!
