Rhino Edge Softening doesn't show up anymore in the render
  • Rhino Edge Softening doesn't show up anymore in the render
    Hi, I use rhino's edge softening tool, (not fillet edge command, the one in the UI to set all edges of an objects). This used to work just fine for a long time but I realized that it is not working anymore for 2 weeks maybe. I tried to understand what can be the cause or if there is a solution on the internet but couldn't find something. Are there any suggestions?
    I use Rhino 7 / 8 WIP&BETA version and up to date v-ray version on windows 10.
    Hello yusufcankat_donmez,
    We are aware of the issue with Edge Softening in Rhino 8, please refer to this forum post. I have also linked your post to the internal issue VRW-4000 and will notify you once it is fixed.​
    Natalia Gruzdova | chaos.com
      Quick workaround: _ExtractRenderMesh and temporary use this instead the NURBS for rendering.
        I tried this one already but didn't work either.
          Strange, it should work - see here:
            Hello,
            is there any news in the meantime?​
            Best
            Marcel
              Hello mackl,
              The issue with Rhino Edge Softening was resolved in 6.20.00 V-Ray build. If you are using earlier version please update to the latest one (you can download it here).
                Thank you, I am using 6.20.03 with latest RH 8 SR7 installation. As soon as I use edge softening, I can't move this object and render on new position. They always stay on untouched. Without edge softening, everything runs normally, but without desired render effect.
                Best regards
                Marcel​
                  Thank you for the details mackl, now I see what you mean. There is indeed an issue with what you describe, for more details please refer to this forum thread.
                  We are working on a solution at the moment, I will link your topic to internal issue number VRW-4450, so that once there is an update we will notify you.
