Cant get Vray to select as the renderer in Rhino 8
  • Cant get Vray to select as the renderer in Rhino 8
    Hi I am using Rhino 8.2.23346, and it says its up to date, I have downloaded the latest vray which has an option for Rhino 8 Version 6.20.01 - I go to select the renderer but as soon as I close the properties tab the command line says Rhino Render selected. - I just cant work out how to get it operational? is it a licensing issue?
    Hello boundary,
    Could you please open a ticket using our contact form​ and make sure to select Technical Assistance Starting the Product under Request type.​ This way our Tech Support team will be able to assist you.
    Perhaps you should try reinstalling V-Ray.
    Natalia Gruzdova | chaos.com
      HI Natalia, I have got it working - however it appears to only work when you change the renderer through the command line - changing through the file properties tab just wouldn't do it! hope that helps
