Vray Properties panel Missing
  • Vray Properties panel Missing
    Hi! I can't see the properties panel. Is there any way to do it?
    Hello, Fran_Drama,
    Thank you for your report! This occurs with the latest version of Rhino 8.3 and is caused by changes to the Rhino API.
    A solution on our side is already being developed and we hope to ship it in about a week or so. Our dev lead is in contact with McNeel's dev team to ensure the final solution on both sides will be solid.
    The only temporary workaround I can offer in the meantime is to revert back to Rhino v8.2, in case you still keep its installer file.
    Peter Chaushev
    Let's keep in touch
      McNeel offered a partial fix for this in 8.5, and as far as I know they will port it back to 8.4
      However I strongly suggest you upgrade to the latest V-Ray version when it is out since our workaround, that will be present there, will completely fix the problem
