Instant crash when deleting bitmap + copy from materials.
  • Instant crash when deleting bitmap + copy from materials.
    Problem: Rhino instantly crashes when deleting multiple bitmaps from a material when one of the bitmaps is a copy.
    Steps to reproduce:
    - Start a new document in Rhino;
    - Open V-Ray asset editor;
    - Create new Generic material;
    - Add a bitmap in the Diffuse slot. (for instance 'Noise A');
    - Add a copy of this bitmap to another slot (For instance 'Opacity');
    - Click on the arrow next to the material to show all the bitmaps attached to the material. ('Noise A' and 'Noise A#1' in this case);
    - Select them both and delete them;
    - Instant crash!
    This also happens with materials from the Cosmos browser.
    The problem is not limited to the Diffuse slot, it happens when one of the bitmaps is a copy and the original gets deleted.
    As a workaround It is possible to delete the bitmaps one by one without crashing Rhino.
    Hello rene_rapati,
    Thank you for this report! The issue has already been reported and logged in our bug-tracking system (bug ID: WEBUI-6935). We will let you know once we have an update on the matter.
    Kind regards,
    Natali Velcheva​
    Natali Velcheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaosgroup.com
      From the release notes of update 2.3:
      Deleting multiple maps of the same texture type simultaneously no longer causes a crash
      Just tested this with the 2.3 update and I'm happy to say the steps posted earlier no longer cause Rhino to crash.
        Awesome, thank you for sharing!
