Edge softening not rendered
  • Edge softening not rendered
    Hi! Vray doesn't detect the edge softening property in rhino. It works in Rhino 7. Hope it's not very hard to solve thanks!
    Hello Fran_Drama,
    Please check which V-Ray version you have currently installed in V-Ray > Help > About.
    Make sure to update to the latest 6.20.02 release if this is not the version you are using. You can download it here.
    Also, try setting higher softening values as a test, so the changes would be more apparent.
    Natalia Gruzdova | chaos.com
      Hi, thanks for answering.
      I have the latest version of each program so I think that's not the problem.
      I can see the softening in the viewport but it doesn´t render.
        Thank you for the screenshot.
        It seems that you have somehow installed V-Ray for Rhino 7 version on your Rhino 8 version.
        Therefore please try to uninstall V-Ray and perform clean installation following the steps in documentation here.
        If there are still some issues or discrepancies please open a ticket to our Tech Support team using our contact form​ and make sure to select Technical Assistance Starting the Product under Request type so they could assist you.​
