Unknown command: _vrayLightDome
  • Unknown command: _vrayLightDome
    This is what I get when I select the dome light, the light sphere & IES
    Thanks for any advice you can offer
    Hello, arail,
    What is the Rhino version you are using?
    Thank you in advance!
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
      Either way this is most likely happening due to an outdated cached .rui file of the V-Ray toolbar. You can do the following:
      From Rhino Document Properties > Toolbars select VRayforRhino, then File > Open and select the VRayForRhino.rui file in the V-Ray installation folder - C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8 (V8 or V7 depending on your Rhino version).
      Let me know if this fixes the issue.​
      Iva Mancheva
      www.chaos.com
        Thanks Iva
        I'm using both V7 & V8
        The path you suggested (Doc Properties, etc.) doesn't take me to C:\Program Files, it takes me to Users > AppData > Roaming
        If I go into Program Files I can see the VRayForRhino Toolbars file but I'm not sure what to do with it (oddly the file says it opens with V
        V8 -
        The V-Ray lights that don't work in V7 do work in V8 but I don't have a V-Ray toolbar in V8
        If I go to Show Toolbars in V8 and scroll down there's no V-Ray listed
        To summarize -
        Some of the V-Ray lights don't work in V7
        All the V-Ray lights work in V8 but I don't have a toolbar
        I hope this makes sense
        Alex
          Hi arail,
          To show the V-Ray toolbar in Rhino 8 you can follow the steps from the following post:
          https://forums.chaos.com/forum/v-ray...y-vray-toolbar
          In Rhino 7 you most probably have to reload the toolbar rui file manually as my colleague has suggested.
          Konstantin
            Thanks Konstantin
