Having Issues with Scatter on Plane
  • Having Issues with Scatter on Plane
    When I scatter my vegetation over my terrain the assets do not sit flush on the plane... Some are lifted slightly in the air. I am not sure why! Please help...Click image for larger version
    Are you sure that in the transforms properties of the scatter geometry, the random translations in Z-direction are set to zero?
      Yes they are all set to 0.
        It could, in theory, also be the scalefactors. But only if the origin of the separate vegetation models is not 0,0. Maybe you can check that. Otherwise I don't have a clue.
          Hello, faris_itum​!
          Is this issue reproducible with all the assets you are using or with just a particular asset?
          Which V-Ray and Rhino versions do you use? Could you send us a packed project (V-Ray>Pack Project...) through our support portal (https://support.chaos.com/hc/en-us/requests/new) with the link from this forum topic in the message?​
          ​Kind regards,
          Ivelina
          Ivelina Mincheva
          V-Ray for SketchUp | V-Ray for Rhino | QA
          www.chaos.com
