2 point Perspective VFB and Rhino Viewport not matching
  • 2 point Perspective VFB and Rhino Viewport not matching
    I've noticed an issue over the past few weeks. When I render scenes using 2-point perspective angles that I've saved, there's a noticeable difference between what I see in the Rhino viewport and the V-Ray Frame Buffer (VFB). I have the "Match Viewport" option enabled in the settings, but there's still a visible difference between the set angle and the rendered output. I suspect this issue is related to the 2-point perspective settings. To illustrate this, I've attached a simple example comparing the VFB with the Rhino viewport. For reference, I'm using an updated version of both Rhino and V-Ray(Rhino 8.12 and V-Ray 6.20.06 on Windows 10).
Name:	Screenshot 2024-11-11 230626.jpg
    Hello yusufcankat_donmez, thank you for the screenshot.
    Regarding the Two-point perspective, as far as I am aware there were some issues in Rhino 8.12 with this feature discussed on McNeel forum - please check for updates and install the 8.13 version and test a new scene and let us know the outcome. If there is still a difference please share your scene in a ticket for us to take a look.​
    Natalia Gruzdova | chaos.com
