Edge trimming not working?
  • Edge trimming not working?
    I have extrusion located inside a polysurface - see the picture. A scatter is applied to the extrusion to but it seems even with edge trimming enabled the scattered object is rendered outside of boundary of the extrusion.
    Am I doing something wrong or is it just buggy?
    Here is the vray version:
      Hello hynek_hrabk,
      Thank you for your report.
      There is currently a known issue with Edge Trimming - it might not work correctly for Scattered objects, which have been significantly scaled or with Cosmos Assets with projects units set to Meters (because they are scaled internally).
      What are your project units and are you using any scaling for the Scattered Asset?
      Kind regards,
      Iva
      Iva Mancheva
      V-Ray for SketchUp | V-Ray for Rhino | QA
      www.chaos.com
        iva_mancheva
        Hello Iva,
        I believe I was using meters and Chaos assets in the project. I have seen some tutorial mentioning this issue has been fixed in new version, so not completely I suppose.
          Unfortunately it is not fixed yet, we will let you know as soon as there is any progress on the issue.
          Kind regards,
          Iva
          Iva Mancheva
          www.chaos.com
            Oh, please work on this fix asap because I' using a lot of cosmos assets in meters and edge trimming is THE key feature for me to upgrade to version 7. Still waiting for fixing the other scatter I've mentioned 2 months ago. Any news here?
