Dirt distribution values
  • Dirt distribution values
    Please, can you change the dirt distribution value to be able to add a negative number?
    I like to use the distribution value to add more contrast to the dirt as in 3ds max, but I found that I could not add negative numbers.
    Please let us do that.
    You can try adding a color correction with a white color in the occluded color and increase the intensity over 1 should make your dirt stronger.
      Thank you for the workaround. Yes, that is one way to do it. But it is easier to add just a negative number to the distribution, how we could do in other V-Ray, like in Max, Blender, etc
        Hi javierrentas​,
        Thanks for pointing this out, we'll take a look.
        Konstantin
          Logged as WEBUI-7257 in our internal bug-tracking system.
