Polygon render region does not work properly with Nvidia denoiser upscale
  • Polygon render region does not work properly with Nvidia denoiser upscale
    Hi, I have tried this many times. if I want to use Nvidia denoiser with upscale, polygon region render does not work, if I turn off upscale, everything is fine. Also if I use normal region render, it works perfectly with upscale denoiser.
    Could you take a look at this, thank you!
    Engine:GPU
    Progressive mode on
    GPU: RTX 4070
    CPU: 13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz
    RAM: 64,0 GB
