Imported 3d Model Lights
  • Imported 3d Model Lights
    I am trying to make outdoor scene, and i need some lamps in it, when i iport them i can not see any light placed in the 3d neither can i see it in my lighting Menu, nevertheless the lights are always on, and are super intense and burn the scene...
    if i explode the 3d in order to change some properties, like lenght of the pendant or so, then the complete element dissapear from the rendering, eventhough is still there as 3D)
    I have tryed everything to turn this lights off, but since i cannot finde them anywhre i can´t.. i am pretty sure this is a one button issue... but WHIIICHHH ONEE? haha i would be VERY thankful for any help
    I just solved it, i didn´t realize the Imported Chaos cosmos Models, have their own settings to be proved in the left wing of the vray asset editor as imported geometry!
      Hello juanesteban_hernandezcardona, thank you for sharing that you have found a solution to your question. Indeed you can find settings for Cosmos Assets in the Asset Editor, you are welcome to check our documentation for more information: https://docs.chaos.com/display/VRHIN...Cosmos+Browser
      On the other note, please be informed that Cosmos Assets can not be edited in terms of geometry in V-Ray for Rhino, as they are created as render-ready assets that load geometry information from the external file (V-Ray Proxy). Even if you merge or explode them and attempt to edit the initial geometry will be loaded from the file during render and the changes will not be applied.​
      Natalia Gruzdova | chaos.com
