lightproperties not accessible
  • lightproperties not accessible
    ...when the properties dialog is floating
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
    hmm, it seems that this bug is not consistent.
      the light properties menu should only be inaccssible when you do not have a light selected. Perhaps it may be unaccessible when you select multiple lights? This could be similar to the material problem you brought to my attention. I will check this out as well
      Joe Bacigalupa
      Developer
      Chaos Group
        O.K., it is not a big problem, but I think how to reproduce this problem, I think though that this is not Vray4Rhino related:
        make sure the properties window is closed
        make a rectangular light
        select it
        press the properties button
        you will now have to reselect the light in order to access its properties.
          I can confirm that this exists, having the same problem.
          /BlueShift
            I will see if there is something I can do to make the Light property be the default property page when selecting a light. This could just be a Rhino thing, but I will look into it because it is irritating.
            Joe Bacigalupa
            Developer
            Chaos Group
              I remember I complained about that long time ago, I think it is something that should be changed at Rhino's side. But why not have a Vray dialog box with all the settings? I particularly dislike the Rhino material interface for material assignment, just too much clicks.
                This can be done. We'll discuss this and see what we can change for the next build.
                Corey
                Corey Rubadue
                Director
                Chaos Group
