lights and objects strange behavior
  • lights and objects strange behavior
    Sometimes after unhiding one object, it doesn't render... if I hide and unhide it again, then works.
    Other strange thing is that a light that was in an exterior scene, doesn't iluminates objects if you create a closed room around it.
    I thought it was a problem of normals direction, but it wasn't because then I created a new light and it worked ok.
    Joaquín Laborda - www.trumdesign.com
    Laborda,
    Can you share a scene with us? Email it to vrfrhino@asgvis.com
    Best Regards,
    Corey
    Corey Rubadue
    Director
    Chaos Group
      I've had that hiding problem too a few times, but it was in older builds.
      Not sure what you mean with the second problem
        Apparently I made a mistake, the second problem do not exist.
        I started working with a single spot (intesity 5) in an exterior scene, and then without the influence of the enviromental light, everything turnes dark, but the spot went on illuminating a bit.
