Hiding
  • Hiding
    I know this happened in older builds, but I just hide a group and it still showed up in the render. Unhide, re-hide, still showed up. Deleted it and it's finally gone.
    Build 8
    Hiding
    Same problem here. This seems to be the same as when using maps and you need to do smth in the scene so that rhino really detects a scene change. If your object doesn't go away with hiding, hit the material edit button on another object, and hit apply without changing a material setting. That should do the trick.
      Hiding
      Yes, it seems to be a geometry table problem.
        Hiding
        I'll see if I can find a way to detect when a hiding takes place. Right now it will only say the scene changed if a material is edited, or an object is removed / replaced / added. I might be able to find something else though
        Joe Bacigalupa
        Developer
        Chaos Group
          Hiding
          While your at it, maybe find something that detects vray options changes too. Because now when you change a lot of settings, and close, rhino doesn't ask to save and just shuts down.
            Hiding
            yes, when anything changes in VRay Options I need to send a message to Rhino to let them knonw the doc has changed. I'll add that on my list
            Joe Bacigalupa
            Developer
            Chaos Group
