I tried to make a quick turntable animation using the Bongo plugin along with Vray. It appears everything works except when it comes to saving the frame. The Bongo script has the command SaveRenderWindow but it cannot be found because Vray's naming is "Vray frame buffer" so the animation rendering is stopped at frame 1.
I also noticed that the time to process the geometry and open the frame buffer has gotten much longer which results in different render times stated between the Rhino command line and the Vray frame buffer. It might have something to do with processing of the Bongo VB scripting.
Regards,
Tony Dean
Sr Design Engineer
Advance R&D
Nike, Inc.
Regards,
Tony Dean
Sr Design Engineer
Advance R&D
Nike, Inc.
