Light color change doesn't render always
  • Light color change doesn't render always
    I have here a simple scene, lit with a linear fallof point light and a skylight.
    Open the file, render persp view. The light will be tinted greenish. Select the light, change the color to a reddish tint. Render again, the image will be tinted red. Now change the light color again to something else, for example purple. Render again, the render will look red again, the light change is not visible. The only thing to do to get the light color change to render, is to select the light, go up and down in the falloff types (make sure you really highlight another falloff type by using the arrows and clicking in the field again). Select the linear again and render: now the change is visible.
    http://www.aversis.be/vrayrhino/light_color.zip
    its possible I forget to tell Rhino that the lighting has changed, I'll check all the lights and see if this is the case. Thanks
    Joe Bacigalupa
    Developer
    Chaos Group
      This was the case. The point light was failing to tell Rhino that it was updated when the color was changed. So that is now resolved. Thanks again
      Joe Bacigalupa
      Developer
      Chaos Group
