Archived Old Bugs
This topic is closed.
  • Re: beta build 11 surface edges...
    Originally posted by nmda
    Has anyone else been experienceing this problem? When we switched to beta_build 11, a lot of our polysurfaces and edges began rendering with dark and light spots around the corner and edges.
    This wasnt happening with 10, and it's the same model. remaking the surface gets rid of it sometimes, but not always. It may be messy modeling, but the model is pretty clean and i dont understand why it hadn't shown up before.
    does anyone have any suggestions or advice on how to fix it?
    I have notice this too. When the edges in the model are not connected and the light is coming out between the edges!
    Some how I believe in the new build 11, the calculation is more precise and it?s harder to get pass without modelling exactly.
    For example I know that my model is not perfect right now (it?s just a sketch) and I haven?t closed all the edges properly yet. But the same model was rendered OK in build 10_5 and now in the build 11 I get this:
    Same model rendered in build 11
    Same model rendered in build 10_5
    est regards,
    <br />//A
    • ***PLEASE POST ALL BETA 11 PROBLEMS HERE****
      The rendering of hidden objects is fixed for the next build.
      Corey
      Corey Rubadue
      Director
      Chaos Group
        Crash:
        • Create a material
        • add several layers (say diffuse)
        • Apply to an object
        • Open that material again
        • Import one of the diffult materials
        • Apply
        • Try to open the material again
        • Crash
        When importing a material with less layers, the old excess layers remain. (This might be the cause of the crash.
          The jagged edges are the result of faces normals not pointing in the right direction.
          To see what faces need to be flipped type AdvancedDisplay at the Rhino command line. Then enable Color backfaces and select a color that will standout. Apply the settings and then go back to your viewport and choose the shaded display type Ctrl+Alt+S.
          This will resolve these bad edges for you. Something like this has come up in a previous build. I will talk with Joe and Vlado about this.
          Corey
          Corey Rubadue
          Director
          Chaos Group
            Today I have seen, the example image of the vray exporter show the Rhino symbol with a wrong flipped background.
            http://www.asgvis.com/RtoV.html#
              Originally posted by Micha
              Yesterday I have tested the layer material with two diffuse layers and a transparency map at the first layer, but have not got an effect. Does it realy work now?
              There was an error there...the transparency maps weren't being used on diffuse layers. Thanks for pointing this out
              Joe Bacigalupa
              Developer
              Chaos Group
                I have problems with the "unhide" command. Often I use the inverthide - I select an object and all other objects will be hidden. Later I unhide anything, but the rendered scene is not updated.
                I took care of this too, thanks again
                Joe Bacigalupa
                Developer
                Chaos Group
                  Yes, previously we had everything hardcoded to do a 180 degree rotation. I'm not really sure why all the images seem to come in this way. I believe we've asked Vlado to look at this, and worst come to worst we'll just put that initial rotation back on by default
                  Joe Bacigalupa
                  Developer
                  Chaos Group
                  • Double Click Problems
                    If I drag a saved .3dm file onto the Rhino Icon or Double Click a 3dm file in explorer, it will open, but the Vray options are all reset to their defaults. Often the materials are gone to.
                    However, if I open Rhino, and Open the fiel from within Rhino, things are fine. Any ideas?
                      Please send a simple problem scene to vrfrhino@asgvis.com.
                      Corey
                      Corey Rubadue
                      Director
                      Chaos Group
                        Drag and drop files in RHINO from explorer crashes Rhino. (small file not a big one!)
                        est regards,
                        <br />//A
                          Ok, yeah Micha had reported the same thing. Does it happen to the same file every time or does it appear to be random? If its the same file, is there any way you could send that to me?
                          Joe Bacigalupa
                          Developer
                          Chaos Group
                          • Double-sided
                            I'm getting facets on surfaces in renderings that are facing the wrong way. I can fix these by flipping the surfaces, but itis tedious. I have my materials all set to double-sided but that doesn't work.
                            Also, I'm losing material assignments when I close a file. Not all, but some. I use a lot of groups and my custom materials reside on a network.
                            I've still had the hide/unhide problem.
                            And materials confuse me. I have no way to click on an object to tell what material its been assigned. The import/export format doesn't seem intuitive. Are you planning more of a browser? Once I make all my materials, I want to browse them when assigning. I wouldn't call this "creating."
                            Craig
                              Now it seems to work here with my crash test file. Maybe the SR5 has helped.
                              • Re: Double-sided
                                Originally posted by craiggorton
                                ...Also, I'm losing material assignments when I close a file. Not all, but some. I use a lot of groups and my custom materials reside on a network.
                                Did you use Rhino SR5? If not, try it.
