Archived Old Bugs
This topic is closed.
  • #46
    ***PLEASE POST ALL BETA 10.5 PROBLEMS HERE****
    Good, I have done some test and get this. If I install the Brazil demo and than Vray, than I can use the mapping tool in Brazil, but not in Vray. Also, if I test Treefrog, than the mapping dosn't work. Also, if I install Brazil after Vray again, than the Treefrog mapping dosn't work too.
    -Micha
    PS: I send this message to the Rhino newsgroup too.
    • #47
      Funny bug: I have used a wood material. Than I decide me to use a grey color only and disable "plugin" and enable "basic". Now, the color of the material is grey, but in the reflection of other objects the wood surface is still visible.
      • #48
        Tiling etc all works fine, but you still need to do the mat edit trick. Adjust the mapping mode, then edit material and hit apply.
        Maybe you're using a very old brazil wip version? It's now 8.
        • #49
          This is actually a "feature". In order for a rendered viewport to evenly remotely resemble the final rendered output our materials fill in all the things in common with the "basic" material. So our materials will translate our reflection /refraction/ diffuse properties to the basic rhino material as closely as possible.
          Joe Bacigalupa
          Developer
          Chaos Group
          • #50
            I have installed Brazil 8 and have try the edit trick - no effect.
            Can you use a box mapping on a sphere?
            • #51
              This is what I get when I assign different mapping to the sphere object:
              Planar
              Cylindrical
              Spherical
              Box
              Surf. UV
              Do we have to install Brazil to access the mapping tools? I thought we did get the McNeel's RCM mapping tools with VR for Rhino!!!
              est regards,
              <br />//A
              • #52
                Maybe yes, didn't think ot that Do you have brazil installed? If not, it probably comes with vray too.
                • #53
                  I have try anything, nothing helps.
                  • #54
                    I don't have Brazil installed! So it must be VRay
                    est regards,
                    <br />//A
                    • #55
                      Hey Micha, a fwe builds ago I also couldn't get it to work while other people did. No idea why it suddenly works here. I had also a problem when using renderinwindow, then suddenly the texture mapping manipulations didn't come trough. But I can't reproduce it.
                      • #56
                        I have rename my Rhino3 directory and uninstall Vray ... and install Rhino again and Vray only ... and it works.
                        • #57
                          The glossiness map doesn't work. The map in that slot is there to replace the number value (black =0.0 and white=1.0 or the other way around). Currently the map has no effect at all.
                          Reflection map also doesn't work correctly. If I use a map with pure black and pure white parts, the white parts indeed reflect 100%, but the black parts return a black diffuse too. The black parts should be 0% reflective so their color should be the diffuse color (in my case a very saturated green which doesn't come trough at all).
                          image:
                          • #58
                            I like the idea of the small and big "M" of the maps. Only the reflection/refraction and light maps show a "M" instead a "m".
                            • #59
                              An update - The mapping bugs are known issues to McNeel. They are working on fixes. No release date is promissed.
                              We will keep you posted.
                              Corey
                              Corey Rubadue
                              Director
                              Chaos Group
                              • #60
                                Somebody needs to kick some butt over at McNeel, I wonder if they actually work there! You guys make vray in a few months, while they need like 1 years to create a 10% working Brazil I hope they don't wait for Brazil to be finished before completing the mapping tools.
