Hello to all users, I'm getting a lot of troubles in my work because I can't make procedural materials come alive in 13.1. I tried several times to unistall the plug-in, deleting the directory, cleaning Windows register and so on but nothing has changed: the new installation is like the previous one!
Could somebody describe a safe and reliable procedure to fix all this mess?
And how can I delete all those "DefaultMaterialnn" from my older scenes?
You can't find procedural textures? hmm ok..do you have adminstrative rights on the machine your trying to install on? There is no special way you need to do it. You just need to uninstall, then install.
The "DefaultMaterials" should remove themselves as long as they are not assigned to any objects.
Thanks for your help, I'm acting as administrator on a WinXP/pro machine and right now I'm getting procedural materials alive by renaming the plugin, restarting system and then in Rhino selecting manually the plugin after restoring the original name. Now it works :P
