Bongo Related Bug
  • Bongo Related Bug
    This was reported previously but I don't know if there was a fix posted.... This may be in the wrong forum, if so, my apologies.
    If there is a workaround I would _very_ much appreciate figuring out what it is:
    Bongo doesn't work with Vray. It renders the first frame of the animation and stops. (It works fine with other, bad renderers).
    Crap, I was assuming this was going to work.
    Please? Many thanks.
    Wil
    Bongo Related Bug
    Will,
    This should work.
    What version of V-Ray beta are you using?
    Corey
    Corey Rubadue
    Director
    Chaos Group
      Bongo Related Bug
      I'm using RC1, and a bongo demo version.
        Bongo Related Bug
        Will,
        Be sure to use a file type that vray can output. Otherwise vray will not work with bongo.
        Corey
        Corey Rubadue
        Director
        Chaos Group
          Bongo Related Bug
          Go to the global options and make sure that "Batch Render" is checked! If not it will only render the first frame and then stop.
          Joe Bacigalupa
          Developer
          Chaos Group
