RCM of RC2 problems
  • RCM of RC2 problems
    Hi ASGvis team,
    please try to get a better RCM tool for the next release. The current version is not good: the interface is much to big and the user can not enable "show widget". It's very difficult to manipulate the mapping without visible projection geometrie. The previous interface was much better - compact and better control.
    Regards Micha
    RCM of RC2 problems
    ... I have try to copy the RCM tool from RC1 to RC2, but I get a bad RCM interface. Do somebody know, which files must be copied from the previous release?
      Re: RCM of RC2 problems
      [ The current version is not good: the interface is much to big and the user can not enable "show widget". It's very difficult to manipulate the mapping without visible projection geometrie.
      You can if you click on show advance UI,the mapping widget is there and you can choose to see it.
      Renee
        RCM of RC2 problems
        Thank you Renee.
          Renee
          yes, and don't lock the default layer of rhino otherwise you can't manipulate the widget anymore even if it is visible... ( lost a lot of time thinking what's wrong with that ! )
          the widget should be assigned to the layer whom the textured object belong to...
            absolutely I also lost a lot of time figuring this one !
            And you are right they should be on the same layer as the object they are attached to.
            Renee
              RCM of RC2 problems
              Yes we have brought many of these concerns up with the people developing RCM. The version of RCM shiping with RC3 has the beginnings of UI fixes - as well as a bit of extra functionality. Please keep in mind that RCM is also a work in progress - and we're very thankful that they are even allowing us to use it in our plugin.
              Joe Bacigalupa
              Developer
              Chaos Group
                RCM of RC2 problems
                Joe, I miss a "frontal" projection (an other name is "camera" projection). Maybe it could be implemented per VfR much easier than in the RCM tool. If VfR can not do it, please post at the RCM team.
                  Renee
                  But I can not move it per mouse or have I overseen something? And I can not hide the widget again.
                    Is your "0" or default layer lock?
                      RCM of RC2 problems
                      Thank you for the hint. I have set a layer invisible, that was the default layer and is renamed. Strange: if I hide this renamed "default" layer, that the widget is blocked. Do the McNeel RCM team now it?
                        RCM of RC2 problems
                        I don't know if they know,but They decided to remove the RCM mmapping tools temporarely from the Rhino 4 beta,because it was not working to their taste,and they are supposed to be working on it.
                        Renee
                          RCM of RC2 problems
                          The version of RCM we got yesterday is working better on several fronts. I'm not sure about this layer issue though. I'll see if I can bring it up with them today.
                          Joe Bacigalupa
                          Developer
                          Chaos Group
