Caustic usage
  • Caustic usage
    Hallo,
    today I have play a little with caustics. I wonder me, that caustics should be enable in GI mode only. From Rhinoman|AIR I know, that caustic could be used in non GI mode too. Is it an interface bug, that the caustic parameters are disabled if GI is disabled?
    Regards
    Micha
    Caustic usage
    I'm glad you reminded me of this. I originally thought caustics were only around in GI modes - so the UI hides it otherwise. However, if you check caustics on then turn GI off the caustics stuff is still calculates the caustic map and whatnot. So my first gut-instinct is that I have just made a UI error in thinking that caustics aren't used in non-GI renders. I'll look further into this. Thanks
    Joe Bacigalupa
    Developer
    Chaos Group
      Caustic usage
      I have tested caustics: a sphere at a plane and a spot light. The progress window tell me, that a caustic map will be calculated. But I can not see a caustic effect. Maybe I have overseen something. Could somebody test it?
        Caustic usage
        works fine for me (except the fact that caustics tab is gone when not using GI).
        http://www.aversis.be/vrayrhino/caustics.zip
          Caustic usage
          Thank you Wouter. It works, but if I replace the point light with a spot, I get no caustics. I have inserted the spot with default settings. Any idea?
          EDIT: I have set "inverse square" and intensity 1000, now I get a caustic effect, but the light is quite dark. My theory, the decay settings are not used for the caustic, it works in "inverse square" allways.
          Simple test: set the point light in "linear" mode and intensity 2 - no caustics.
          Conclusion: caustics dosn't work in "linear" and "inverse" decay mode. A Bug?
            Caustic usage
            I'll ask Vlado to take a look at that issue
            Joe Bacigalupa
            Developer
            Chaos Group
              Caustic usage
              Nope, this is not a bug. Inverse square decay is the physically correct one. Because of the way caustics are calculated, the inverse square decay is obtained automatically and there is no way to change this - it's an intrinsic property of photon mapping.
                Caustic usage
                Thank you Vlado. I have suppose so that it is so, but I have not find any info about it at the help page. MAybe you could add an info.
                Regards Micha
                  Caustic usage
                  In my example, I used a point lights with inverse decay and a light multiplier of 1000.
                  If I for example use no decay, and a multiplier of 1, you see no caustics. To solve this, simply increase the global caustics multiplier to 1000 in the caustics rollout.
                  Works with spotlights too.
                    Caustic usage
                    Thank you, good workaround.
