VIP - use of block and worksession
  • VIP - use of block and worksession
    Hy guys,
    my VIP ( VERY IMPORTANT PROBLEM) is that I can't have the correct render using block or worksession object inside the scene.
    Some of the block obj doesn't appeare in the rendering also if the materia is "double sided".
    The other problem is with the worksession, I can't maintain the texture map coordinates when I attach a new file in the worksession. (For architectural rendering is very important this).
    Thank a lot.
    Riccardo
    Hy all,
    I solved the problem with block by re-installing the version 1 ( maybe I had problem the past updating from RC3 to v1.0)
    BUT
    still remain problem with the external file linked via worksession.
    It's only my problem?
    Bye
    Riccardo
      I'll ask the RCM development team whats going on with the lost texture coordinates. As far as blocks not rendering - perhaps if you could send me a scene I could see whats happening. I believe another user has posted in the past couple days with a block rendering problem when it was imported from AutoCAD.
      Joe Bacigalupa
      Developer
      Chaos Group
        I have the same problem with worksession and blocks
