Hello,
I am not sure if it is a bug or not,but if you design a material with a bump map and decide to remove it ,clearing the map,the check box can be still checked,and the result is that the object won't render at all.It is in the drawing but does not render.
I look for that problem a while before figuring out that I forgot to uncheck the bump map.
Thanks,
Renee
Thanks,
Renee
