Rhino V4 crashes when rendering animation
  • Rhino V4 crashes when rendering animation
    hi
    i am trying to render an animation of 300 frames
    the rhino file size is 55mb, its a short fly-in \ turntable sequence of a machine, i have tried to follow the tutorial for rendering animations which on found in the tut section, plus i have also converted all my objects to meshes(as low mesh as possible) i have animated the camera with the bongo plug-in and done the pre pass with the IR Map. when i try to render the full sequence at 720x576 rhino keeps crashing.
    is this a problem with bongo,vray or rhino?
    my pc has 2GB of memory and i am using 4 render slaves but that does'nt seem to help as i get a crash every time.....
    i really hope someone can help as this is a very frustrating.
    Neil
    Re: Rhino V4 crashes when rendering animation
    Have you tried the animation without using DR? I have a similar problem where i can render out the first frame but experience a crash only when using DR. Going solo I can render the animation fine (just takes 4 times as long!). Haven't found a fix yet so i'm still looking for one.
    pk
