Saving Output Image
  • Saving Output Image
    I'm currently running into a bug which I can't seem to figure out. No matter what I do, if i try to save a "Render Output" file the render will always cancel itself.
    I believe this bug also stems into the fact if i try to render an animation or batch rendering, the images will never save in the specified folder even though it says it has "succfessfully been saved."
    Re: Saving Output Image
    Hi
    I got this issue when the folder that I have on the render Output is not a real folder on your hard drive. Please double check that the folder exist on your machine.
    Best
      yes i am saving the images to an existing folder on my desktop. I also even tried saving it directly to the desktop but the images still do not save.
      The message below is for an animation but it still applies to batch rendering.
      Save file name ( Browse ): "C:\Documents and Settings\pc-32\Desktop\d_299.jpg"
      Image successfully saved as C:\Documents and Settings\pc-32\Desktop\d_299.jpg
      This is why I am confused, it says it saves but obviously doesn't.
