Vray doesn't notice custom render mesh
  • Vray doesn't notice custom render mesh
    Vray doesn't respect custom render meshes.
    That is: it only does after reopening the file, or after ALSO changing the global mesh settings.
    Cheers,
    Gijs
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
    Re: Vray doesn't notice custom render mesh
    forgot to add: this is the case in both V4 as well as in V5
      So far I know it's a Rhino bug and _refreshshade should help.
        I already tried that but that doesn't help...
          It looks like vray doesn't recognize custom mesh attributes as geometry modifications, so if you have already rendered once,
          vray does not export the mesh again but use a sort of cache of the previous render....definitely a BUG.
          A workaround could be move your object than Undo and hit render.
