Bongo 2 doesn't work - Error saving imageCommand: visOptions
  • Bongo 2 doesn't work - Error saving imageCommand: visOptions
    if I start to render an animation per Bongo 2, than the first frame is rendered and than the process stop with the rror message at the command line:
    Command: -_SaveRenderWindowAs
    Save file name ( Browse ): "D:...PNG"
    Image successfully saved as D:...PNG
    Command: _BongoRenderAnimation
    What can I do?
    Thanks in advance,
    Micha
    I changed the VfR output to viewport and now I don't get the error message, but Bongo stops after the first frame like before.
      Solution found - the image save path contained letters like "ΓΌ". A simplier path was the solution.
        H Micha
        Thank you for share this.
        Best
