importing an older drawing
  • importing an older drawing
    In Vray ADV and Rhino 5 64
    Each times I import an older drawing that has been set-up in an earlier version,Rhino crash.I f I open that same drawing in a fresh instance of Rhino it opens,correctly.Or if I open it in Rhino ,where Vray is not loaded,so I know it is a vray problem.So to correct the problem I open it alone remove all the materials and save it as version5.
    Also when importing or copy paste an object from one drawing to the other,the material list does not get updated.I have to close Rhino and reopen to make the materials appear in the list.
    Thanks
    Renee
