DR and 1.5 - a list of workarounds
  • DR and 1.5 - a list of workarounds
    After much work I got the spawner running at four slave machines. I found it's good to know:
    * don't start 1.05 and 1.5 spawner parallel at the slaves (per autostart or service)
    * don't use "shared folder", it doesn't work
    * don't use letters like ä, ü, ö for texture names
    * don't use textures at Rhinomaterials, DR ignore them, use VfR materials
    * Lens effects doesn't work
    * don't use DR for LC, if you use a master machine with a lot of cores and a lot of LC passes
    http://www.chaosgroup.com/forums/vbu...sn-t-work-well
    * disabling the VRLservice is needed to avoid the start error
