RT locks when changing glass transparency texture
  • RT locks when changing glass transparency texture
    I've got a falloff texture in the transparency slot (diffuse tab) on some glass windows (transparent when looking flat-on to the glass and much less as you view the glass at an angle).
    When I try to alter the values of this texture RT locks up. I have to save the file, exit Rhino and re-start, open up the file again and then restart RT to get it working again.
    Regards,
    Rob.
    .:www.mcphersonyachtdesign.com:.
    Hello Rob,
    I just did a quick test and everything worked as expected.
    Could you please attach a simple scene and let us know which parameters should be altered in order to reproduce the issue.
    Thank you very much in advance.
      Svetlozar,
      I can't seem to replicate this problem again. Everything working fine now, sorry! Just ignore me. I must have been fiddling with something else at the time which caused the lock-up. If it happens again and I find what it is I'll send you a scene.
      Sorry for the false alarm.
      Regards,
      Rob.
