Block Instance - Objects Disappearing
  • Block Instance - Objects Disappearing
    I've noticed that when I've block instanced in an object, if the case of the material names don't match the objects fail to render.
    So in the block you might have a material called 'white gloss', and in the main file where the block has been inserted the material could be called 'White Gloss', the object becomes invisible on render.
    Has anyone else experienced this?
    I think this is not limited to blocks, at least in the example you cite. It's possible to have two different materials with different cases in the material editor which can cause issues, see my post here:
    http://forums.chaosgroup.com/showthread.php?80247-material-name-uppercase-vs-lowercase-bug
    if you are also seeing things disappear with totally different material names, then maybe it's something else.
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
      it could be a related bug. but I'm finding objects with materials applied which might not be in the material editor (or which have case differences) simply not rendering at all (as though they were invisible).
      I haven't been able to replicate when it's not a block instance.
        Interesting. I've also found that imported meshes will sometimes be invisible until a vray material is applied. Wonder if all these are related somehow.
        emil mertzel
        vray4rhinoWiki
          if it is an old material coming from an earlier version of Vray,it happens often.
