Problem with materials of the same name
  • Problem with materials of the same name
    When I import geometry in a file that already has the same material, I have the choice to keep the material in the file, overwrite it, rename the new one, etc.
    But when the capitalization of the material name is different, the dialog box doesn't show and the two are visible in the material editor.
    Then V-Ray seems to be confused and won't render the objects that have this material.
    In some files, even if I delete the offending materials and purge unused ones, then re-import it, it doesn't work.
    I managed to save a small part that shows the problem.
    Part.zip
    Known issue, not sure if it's been resolved in the nighties:
    http://forums.chaosgroup.com/showthr...-lowercase-bug
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
      I have a recent build, so it's still a bug...
      Would be nice to have a comment from Chaosgroup,
        I did report this with the bug reporting feature, never heard more about it.
        emil mertzel
        vray4rhinoWiki
