I remember on VfR1 there it was possible to work on two projects at the same time and each frame buffer remembered his own last used save path. Could it be possible again please? It's a lot of work to find the right folder during working for different clients at the same time.
Also, it's needed that saving materials would keep his own last used path, since materials are saved in an own library folder and not at the image output of the last project. And finally it could be good if frame buffer curves/... would be saved/opened to/from the last used image saving folder.
So far I remember so it was working at VfR1. Back to the roots.
