Hosek sky - Horizon Offset
  • Hosek sky - Horizon Offset
    Hi everybody!
    I am currently testing the 3.6 trial, and I am having a problem with the Horizon Offset in my V-Ray Sun config. The adjustments I make, are only visible in the interactive GPU render mode. When I go back to production CPU mode, the offset and Albedo color render as default. Is this a known issue?
    Edson Maruyama
    Architect
    Originally posted by maruyama.edson View Post
    Hi everybody!
    Hi maruyama.edson,
    This isn't a known limitation.
    When I tested this on my system the offset works as expected and the sky is identical on both CPU and GPU.
    Can you share a simple scene that we can test further?
    Regards,
    Konstantin
      After closing Rhino and opening back, the hosek sky behaved normally. I don't know what happened.
      Another issue I faced while doing this, is that, opening a .vropt of a scene that had a vraysun in it, creates a vraysun in the new file, but just in the V-Ray asset editor, not in the Rhino viewport.
      Thanks for the attention!
      Regards,
      Ed
      Edson Maruyama
      Architect
