DOF Problem
  • DOF Problem
    Hi guys!
    I use Rhino 5.0 / V-Ray 3.60.02
    I downloaded the last V-Ray for Rhino relase.
    I have a problem with the "PICK POINT" of the DOF.
    when I select an object, after pressing pick point, the focus distance is always wrong.
    I do not know if it's just my problem.
    Martino
    Hello, Martino,
    Could you please provide a screenshot illustrating the way the focus distance value is miscalculated?
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
      Originally posted by Peter.Chaushev View Post
      Hello, Martino,
      Kind regards,
      Peter
      Hi Peter,
      thank you for your reply.
      I made a short video. It was easier than putting screen shots.
      I do not know, maybe it's just my problem. I hope you help me.
      thank you so much.
      Martino
        Thank you the demonstration!
        We retested the feature. Turns out the distance is always properly calculated, but the selection itself is trickier with Nurbs objects (Focus point snaps to objects just like a regular Point). There's not much that can be done for improving it but the devs will look into possible solutions nevertheless (mainly the ability to select focus point in any view, not just ones with perspective projection).
        Kind regards,
        Peter
        Last edited by Peter.Chaushev; 30-03-2018, 07:48 AM. Reason: Edit: clarified details
        Peter Chaushev
        www.chaos.com
          I dont know if this is useful here or not for your problem but I find the command vrayCamFocus and passing the Object option to be a quick and easy way to set the focal point to an object that has worked reliably.
