Lands design bug
  • Lands design bug
    Please read here:
    http://rhinolands.com/forum/topics/l...=msg_com_forum
    Hello,
    Just downloaded the plugin and tested it. The issue will not be reproducible in the next V-Ray version.
    For now, the workaround would be to manually edit the file path of the diffuse texture (use vrayMtlFromRhino command, then the V-Ray Material editor).
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
      Thank you, I forward your answer to Albert from Asuni.
        Update: the workaround from my previous post may not be sufficient. It could also require disabling materials' Opacity map checkbox and enabling "Diffuse Texture Alpha".
        If anyone is finding it impossible to overcome the current issue, simply send me a PM.
        Kind regards,
        Peter
        Peter Chaushev
        www.chaos.com
