Problem with Picture Frames
  • Problem with Picture Frames
    I've been having problems rendering properly picture frames in vray 3 for a long time which I never had in vray 2.
    Picture frames from a png texture generate a Rhino material and it's alpha mask automatically. However in version 3 all I get is a white silhouette even though the material and mask files are available.
    See attached scene example and output. The same scene renders correctly in vray 2.
    Using v 3.60.02 adv (trial) and Rhino 5 latest SR
    PicFrame-problem.zip
    Click image for larger version  Name:	Output-vray3-vr3.jpg Views:	1 Size:	55.9 KB ID:	992393
    Please fix this asap
    www.marinevisuals.com
    3D Visualization for the Marine Industry
    Hello, Juan,
    Thank you for reporting this. Issue is already fixed in our internal builds. The solution will be available in v3.60.03.
    In the meantime, you can use the command vrayMtlFromRhino and then repath the diffuse texture file through the V-Ray Material Editor.
    Same issue is responsible for https://forums.chaosgroup.com/forum/...nds-design-bug
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
