Hello,
I'm not sure if this is a bug or something I'm doing wrong. I have an object composed of many m eshes that I want to transform into a vray proxy to use in a scene. The meshes are not grouped or in a block. Each of the meshes has a material assigned with V-Ray Material Asset Editor. These materials have been converted from Rhino materials. The file was originally imported from a sketchup file. The file was in 2014 skp version and was saved to sketchup 8 version before importing to rhino. When I export the to a vray proxy (replacing the original objects) it works perfect. But if I then import the vrmesh file to the scene I doesn't include any of the original materials.I have tried different ways to assign the materials to the objects but the results are the same.
I can't upload the 3dm file or the vrmesh file, I get an invalid file error...
