Ok, not sure if problem isn't coming from Rhino tho.
Activating render view from _Set object shading attributes I can see the texture properly only if the Mapping widget is equal or bigger than my model. If my widget is smaller, it does not appear repetitive as it should. Any thoughts? Thanks so much
Bellow the textures shows well as the mapping widget is not smaller than my object:
