Material Environment Overrides and Dome Light interaction
  • Material Environment Overrides and Dome Light interaction
    hi there Chaos users.
    I am finding that when I use the Vray dome light work flow rather than a sun light setup the Material Environment Overrides do not render.
    I want one material in particular to reflect something different- which I can do using sunlight etc.
    They do show up in the material preview panel. Is this always the case or am I missing something.
    Regards Jahnyboy
    Set the Dome Light as invisible and use the same texture in the Environment Background slot. Adjust the background and env. override intensity values if needed.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
