Does V-Ray not scale well on high-res monitors? Can it be updated?
  • Does V-Ray not scale well on high-res monitors? Can it be updated?
    So both on 4k and 5k monitors I noticed that the buttons are super small and the text is mushed together on the adjustment sidebar. I tried playing around with different scaling in Windows settings, but no luck. Also, I know Next was a big update, but are there ever smaller incremental updates?
    Hello, and thank you for posting about this issue!
    This is a known limitation of the VFB. We did not manage to work on it for the initial V-Ray Next for Rhino release. I will escalate this to our devs. Hope we can offer a solution in the upcoming update.
    As a workaround, you can set the UI scale by using the environment variable VRAY_VFB_UI_SCALE. You can read more about this temporary fix at https://forums.chaosgroup.com/forum/...509#post980509
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
