The workflow with 'Use As Replacement' is to select the material that you want to copy and select 'Use As Replacement'. Afterwards, select the material that you want to replace and click on 'Replace All References' or ‘Replace In Scene’.
Replace All References - This will replace this material in all places that used the replaced material previously applied to including Two Sided and Multi Material. Replace In Scene - This will replace the material from all objects in the scene.
